Problem with idle after porting TB
Old May 2, 2002 | 05:07 PM
PatrickZ28's Avatar
Default Problem with idle after porting TB
I ported the thing out and epoxied up the holes but now I can't get it to idle. The first time I didn't have enough air getting to the IAC sensor ( think that's what it's called ) so I fixed that. Then I guess I drilled the TB blade out too much cause then it was idling at 1400rpms. So I downsized the hole and now the thing is surging and won't idle. Ideas on what could be wrong? Is there not enough air getting to the PCV? Thanks
Old May 2, 2002 | 08:01 PM
WILWAXU's Avatar
Default Re: Problem with idle after porting TB
Well.. that's why most of us suggest not monkeying with the blade at all.. just removing the "bump" and polishing it up.
If you ground around the are that the blade contacts, you probably have air "bleeding" around the edges.
Old May 2, 2002 | 08:04 PM
dand35th's Avatar
Why not just turn up the throttle blade screw? I had to mess with that to get good starting and no surging, go in a 1/2 turn at a time. It works best when car is cold then mess with it till it doesn't surge at startup.
