smaller belt modification...
Thanks,
Mike
<small>[ May 03, 2002, 01:59 PM: Message edited by: KillerD ]</small>
It's definitely got some gain, but the load on the pump is minimal when you're running in a straight line.
I would avoid unless you're looking to eeek out the last hundredths. I do it 50% of the time. The others I get lazy.
If you're running 8.1s and haven't already did the following, I'd do it:
remove back seat
run with low gas (less than a 1/4)
remove or at least disconnect the front swaybar
take any junk/tool boxes, jack and spare out of the car
air up front tires really high
short belt has consistently shown to drop .03 or so in the 1/4, so not much in the 1/8th at all. At the same time, it would suck to run 8.00 or 8.01
J.
<strong>Once you run the belt under the water pump pulley and then go up over the small pulley, you'll go straight down to the alternator.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">There's a small correction. I do not go over the small pulley; I go under it. It won't be used at all. I installed my short belt yesterday for the track, so it's now fresh in my mind. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I agree that the faster you go the more stable the car will feel at the end of the track w/ no power steering.
I went 11.73 in not the best weather.. so it looks like I might have picked up a little too <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
