idea for crankcase evac
Old May 5, 2002 | 05:31 PM
cablebandit's Avatar
Default idea for crankcase evac
I was just porting my stock manifold when I thought "why cant we use the egr port on this manifold for a cranckcase evap setup. I'm not sure what the egr pump/motor does but if it actually sucks exhaust in to the intake manifold, couldnt you wire it in reverse....to a wot switch and plump it to suck from the valve cover and go out the exhaust manifold? The air pump plumbing seems to have a one way valve in it and could maybe do the same thing. Just a thought...i know you guys will tell me why it wont work.
Old May 5, 2002 | 07:25 PM
99 WS6's Avatar
Default Re: idea for crankcase evac
I was thinking about using the AIR pump as an evac pump. I figured I would hook it up to a hobbs switch, and at 0 psi, it would come on and suck out the crankcase. The main reason is because the check valve in the EGR hose to prevent pressurizing the crankcase will effectively shut down the EGR system so it will only vent pressure (no crankcase vacuum). It is still very early in the planning stage though (no turbos yet).
