BIG Single Exhaust??
Mrr23, who is a member on here, gained 15RWHP going from a 3" y-pipe exhaust to the Bassani 2.5" true dual exhaust.
He actually made more power with the TD's and ran faster in the 1/4 mile then he did with an open cutout. And I've never seen a y-pipe setup make more power than an open cutout.
Heres his website:
http://www.stealthram.com/2000pontiacformula.html
I think that should answer your question
There's a reason all high end sports cars come with dual exhaust with a crossover of either an X or H pipe. It's best for flow, exhaust velocity, and sound.
A true dual 3" system with an X-pipe will make more power, flow better, and have high exhaust velocities than your 4" y-pipe setup. Its a fact, physics are working against you. If you don't believe me than try it yourself, you will make more power and torque than you have now.
Have you ever dynoed the same car with a true dual and then with a big single and Y pipe?
seems like a decent gain when comparing 2 already "high capacity" exhausts
Don't talk **** before you know the facts.
Yours has the perfect depth. I did notice from your pics that it looks like you could use some wax on your paint though
Yes she needs a buff job have a little oversparay on her from brake caliper red paint mod and sitting in the garage for the past 2 mo. I'll get right on it brah.
https://ls1tech.com/forums/generation-iii-external-engine/565945-3-ory-4-i-pipe-cutout-into-slp-dual-dual-pics.html
