Fast 90 map sensor problems-Corvette
Old Apr 30, 2007 | 10:56 PM
lccobra's Avatar
Default Fast 90 map sensor problems-Corvette
I recently went to the dyno to check my a/f and tune out (2001 Z06 just bought the car) and was presently surprised to see that the a/f was lean in the 13.80s. A local tuner was there and was looking things over and noticed that when my car would go to wide open throttle the map sensor was everywhere. So knowing this I looked around (see post https://ls1tech.com/forums/showthrea...ensor+corvette )and found out that users with the fast 90 intake had issues with the map sensor rubbing up on the fire wall and needed to be relocated because of issue I figured that might be the problem. Does anyone have a write up describing how to relocate the map sensor and I heard of getting a different type of sensor would be beneficial. Any help would be much appreciated.
Old May 1, 2007 | 05:14 AM
vettenuts's Avatar
Responded on CF. I re-located mine, it isn't pretty but it worked (so far). Haven't dynoed yet, but car seems to run strong and I have plenty of clearance back there now.
Old May 11, 2007 | 10:23 PM
mm2003's Avatar
t t t
