help on tach problem wire
Old May 12, 2002 | 10:44 AM
okcss's Avatar
Default help on tach problem wire
put my heads back on now my tach does not work.where is the tach wire??
Old May 12, 2002 | 11:31 AM
XtraCajunSS's Avatar
Default Re: help on tach problem wire
The tach wire is #10 on the Red PCM plug. it is white.
Did you forget to plug in a sensor? The camshaft position sensor is behind the intake on top of the block...
Shane
