Next Induction Mod
Old May 13, 2002 | 07:49 PM
RagTop's Avatar
Default Next Induction Mod
I'm planning to spend about $300 on an additional induction mod. I presently have a GMS lid, Free Ram Air, K&N filter. I'm considering either the K&N FIPK, the Volant Induction or adding a GMS or other 85 mm MAF to the existing stuff I already have. Which mod would provide the biggest performance improvement over my present induction arrangement and whats the difference between the GMS MAF and other 85 mm products like SLP?
Old May 13, 2002 | 09:09 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Default Re: Next Induction Mod
I'd definitely keep your lid. The FIPK will suck up a LOT of hot air once the hood is shut. As for the MAF's, I would leave the stocker. You're not going to get any gain from added flow through the MAF. The gains from MAF's come from added timing and leaning out the a/f ratio. Patrick G tested a stock, descreened MAF vs. an 85mm MAF, and he didn't gain or lose any HP by swapping the two. FWIW, he has a heads/cam A4 that consistently dynos 400+ RWHP. If you want a worthwhile induction mod, get a FTRA or Whisper ram air kit.
__________________
