1997 Camaro Valve Cover Question
Old May 15, 2002 | 10:50 PM
mailman's Avatar
Default 1997 Camaro Valve Cover Question
I need help removing the right side valve cover. I know I have to loosen the trans tube and rear engine bracket but what's the best way to do this? There is almost no clearance from the top of the engine. Also, the manual calls for removing the oil fill tube prior to cover removal. How does the tube come out...pull straight or twist out? Thanks in advance.
Old May 16, 2002 | 02:30 PM
WILWAXU's Avatar
Default Re: 1997 Camaro Valve Cover Question
Wow... any LT1 guys out there?
Might do better with this question over on www.camaroz28.com/
