Install questions
Old May 6, 2007 | 04:42 PM
Wassko268's Avatar
Question Install questions
I just finished installing a Meziere electric pump, and an SLP underdrive pulley. I have power when I turn on the key but it is running at 210 degrees. I have a heavy duty radiator and it was running at 180 degrees before. The pulley went well but my speedo is buried past 150 mph?????????? What the f_ _ _?
Old May 6, 2007 | 04:53 PM
Tainted's Avatar
well, i cant answer the one question but you should know that the 99-02 guages are dummy guages as far as tempature. they will read a certain * as soon as its warmed up no amtter what and only shows an overheat condition
Old May 6, 2007 | 04:57 PM
Wassko268's Avatar
I have aftermarket autometer gauges in the pillar for that exact reason.
Old May 6, 2007 | 05:01 PM
Tainted's Avatar
ok, im out of suggestions for ya then, but heres a free bump for ya
Old May 7, 2007 | 06:50 AM
radkon's Avatar
You probably have air in the system. Make sure you burp the cooling system well. If it doesn't get back to normal you may have gotten a bum T-stat (rare but it does happen).
