Coolant crossover conversion questions.
Old May 17, 2007 | 04:54 AM
NIIN20's Avatar
Default Coolant crossover conversion questions.
I'm still new to the LSx stuff and am doing a retro fit into an older vehicle. My question revolves the coolant crossovers. I am gonna convert mine over to braided fuel hose and fittings and am curious weither I should just block off the rear or connect all 4 together? Would there be any difference in cooling system demand levels to decide which to do (i.e. horsepower level)?
Thanks!
Old May 17, 2007 | 05:02 PM
5_02ls1's Avatar
this is the way i done mine"way cheaper"i connected the2 rear lines on mine..it works great too..
Old May 18, 2007 | 01:58 PM
NIIN20's Avatar
Connected to each side or connected all 4 together? Thanks
Old May 19, 2007 | 08:38 AM
00454sscamaro's Avatar
the back being plugged off is beleived by some to help make no7 go.. i have a fast and even though it was a pita to make; all mine are connected. went over the intake instead of under. made my own blocks out of brass and ss tube to connect to rubber line and a few t fittings.
Old May 20, 2007 | 10:31 PM
NIIN20's Avatar
So your saying that some think that blocking the rear steam crossover contribute to the problems with the #7 cylinder? Thanks.
Old May 21, 2007 | 02:09 PM
SSdreamz's Avatar
blocked mine, when i converted to the LS6 intake......my number 7 spun a rod bearing...could this have been the culprit?????
Old May 21, 2007 | 09:29 PM
98Camarod's Avatar
****...don't tell me that, I just capped mine off.
Old May 21, 2007 | 10:16 PM
kistlerjm9's Avatar
dont block it off connect all four together. you can find a number of fried number 7's with the rear capped.
Old May 21, 2007 | 10:46 PM
98Camarod's Avatar
Just curious, all the cars with the ls6 intake from the factory, are those blocked off too?
Old May 22, 2007 | 12:04 AM
WILWAXU's Avatar
Yup. Just the two block off's in the back.
Old May 22, 2007 | 05:35 AM
98Camarod's Avatar
Then that is garbage. They wouldn't have blocked them off if there was anything wrong with it. I believe that the steam will travel to the highest point and then go to the radiator which is even higher.
Old May 22, 2007 | 08:48 AM
Stang's Bane's Avatar
Thanks!
You can order some really cool blockoffs from Wegner. I did,a nd then I ordered the hose and AN fittings from summit. Should be really trick looking..
Old May 22, 2007 | 11:54 AM
daryl2cb@yahoo.com's Avatar
If the rears are capped off, and the front is still joined together you should not have an issue. this is the way that all ls6's came from the factory, as well as 01-02 f-bodies equiped with a ls6 manifold. If you see a number of number 7 going out, look at the situations. No2, fI, high mileage, beat to ****, or generally worked on by someone who should not work on a car, or other factors. Now do not get me wrong here, things happen, but if proper coolant manitaince is done and motor is maintaned, things usually just do not happen out of the blue. Cap them of and put your time and money elsewhere, IMO
Old May 22, 2007 | 01:25 PM
NIIN20's Avatar
Thank you. I was just speculating ideas from the Gen1 stuff like tying the coolant passages together front to rear, etc. Didnt know if any of that had any merit on these engines or even mattered or if it would hurt anything. I'm sure this is the least of my worries on my build but I like the little trick things to stand out and function and have reason. I dont see the steam crossovers doing much to # 7 myself either unless the engine is tuned to the edge and that being the hottest cylinder it ges first.Thanks.
Old May 23, 2007 | 03:06 AM
NIIN20's Avatar
Found Wegners site, THANKS! Them look cool enough! I was gonnna drill and tap the head directly but wasnt sure if the there would be clearance to the head bolt/stud access or not.
Old Jun 24, 2007 | 12:50 PM
Project GatTagO's Avatar
It may be garbage on a stock Z06, but GM doesn't account for bigger cams, questionable tuning, and so forth. I believe that you should connect all 4 together.
Andrew
Old Jun 24, 2007 | 02:32 PM
SSdreamz's Avatar
i have a lower mileage car, no N20, no forced induction, and i certainly dont beat the **** out of my car! hell the car is lucky to see 3k miles a year. mostly to shows and a couple of cruise nights. its just one of those things that happens......
