Throttle cable question
Old May 17, 2007 | 09:05 PM
SSTowerman's Avatar
Default Throttle cable question
My gas pedal travels about an 1 - 1 1/2 inches before it starts to engage the throttle body blade. Is there a way to tighten it up a bit?
Thanks
Old May 18, 2007 | 11:25 AM
SSTowerman's Avatar
Geez, I guess nobody knows how.
Old May 18, 2007 | 11:31 AM
dnm12's Avatar
do you have ASR if so they are those little boxes on the cabe lines them selves which is you move away from eachother should tighten the cable
Old May 18, 2007 | 11:34 AM
SSTowerman's Avatar
Yes I do have ASR. I opened that box but couldn't really grasp what I needed to do. I'll look again.
Old May 18, 2007 | 01:58 PM
PAGregSS's Avatar
Remove the clip from the adjuster and slide the barrel inside until the slack is gone, then snap the clip back down. You can see the threads on the barrel inside that engage with the clip.
Old May 18, 2007 | 06:10 PM
SSTowerman's Avatar
Thanks. Kind of a chincy little setup if you ask me. Anywho, I got it.
