idle
Old May 20, 2007 | 10:26 PM
daniel6718's Avatar
Default idle
ms3 cam only ls6 intake longtubes...
how are yall getting these things to idle? i had a mail order tune from bryan at pcm4less...hes been great to me a done a great job everytime i needed
problem is i adjust the screw so it wont die when its warm(he mad it give a few % throttle when it goes into gear)
now when its cold it will idle but you cant touch it or it will die...
i can adjust it to idle up more when cold(about 1600 and it will go into gear but it then when its warm its idleing at like 1500...and everytime i take it outa gear it goes to 2k
also when i start it it wont start when cold and run by itself until it warms slightly, to get it to start you have to blip the gas to get some air in there....
i was told to adjust the screw on the t/b to 7% i think or 7mv
and the iac should be about 40 or so? im guessing i need a scanner what do i need to be looking for while im doing this?? are yall getting thes big cams in stock bottom ends to idle good when cold and hot and not die going into gear?
