Ported Tb Size?
Old May 31, 2007 | 05:39 PM
kicksZ28's Avatar
Question Ported Tb Size?
The TB on a 98 Z28 w/LS1 is I think 75mm. When the TB is ported what is its new size? Is it about 80mm?
Old May 31, 2007 | 09:11 PM
Bo White's Avatar
75mm...its just that you port the housing infront of the blade out to make it a true 75mm were before its a 75mm blade with a 72mm hole to breath through in front of it
Old May 31, 2007 | 09:42 PM
kicksZ28's Avatar
Default Tb
Thanks, I guess I am going to have mine ported. I was torn between a new edelbrock TB and having mine ported. I have decided to get mine ported and save the $$ that i would spend on a Edelbrock. I was just curious as to if the porting made the size close to 80mm then I would go with a new TB.
