To X or not to X, for true duals.
Old Jun 3, 2007 | 12:40 PM
fastGBcamaro's Avatar
Default To X or not to X, for true duals.
I am building a LS2 stroker motor for my camaro and I am going to run true duals off of my new Kooks headers. I am still undecided about what muffler I am planning on running off of the collectors (xr1's, bullets, or magnaflows) Should I run an X pipe or not? I think the only difference is going to be the sound. Is the sound of a true dual setup with an X pipe worth the extra money for the X pipe. I have tried to listen to to exhaust clips on here of both setups, but most of those clips just dont do the cars justice.
Old Jun 3, 2007 | 01:10 PM
Tainted's Avatar
go with an X pipe. the X helps balance out the flow and does help your hp
Old Jun 3, 2007 | 01:12 PM
d james's Avatar
I think the X sounds a little better, but for the ground clearance issues you can come across, I'd skip it. When I had mine I welded and unwelded that thing a few times tryin to get more clearance, but the darn torque arm made it damn impossible. From what I remember it lowers the sound ever slightly since it balances out the pulses from each cylinder bank. The X will give you a few more ponies over not having it-the reason many go with it as well. I don't remember what the clearance was, but I think it may have been around 3-3.5 inches under the lowest part of the X (memory from measure), maybe a different brand would've given better clearance, but I couldn't get it any better. I only had a problem over speed bumps, but that still bothered me. If you don't mind that, and want every bit of power I'd say get one because they do produce better power results. Hope that helps with your decision
Old Jun 3, 2007 | 02:52 PM
barracuda_440's Avatar
get a TSP setup. it fits fine, sounds amazing and you wont be disapointed.
Old Jun 3, 2007 | 03:34 PM
DSRCAM's Avatar
my friend had a x pipe and i took him with my h pipe by the way we had the same mods except for the intake he had an ls6 i had an ls1 and my car is a4 his an m6 and both cars had lt's/true duels/
