Exhaust Installation Question: Need Help
Old Jun 7, 2007 | 12:52 PM
02pewterZ's Avatar
Default Exhaust Installation Question: Need Help
Ok, so for a while now I have had problems with SLP LM coming lose and rattling. My question is about the placement of the clamp between the Y-pipe and the I-pipe, because I can never seem to get this thing tight enough. Where is the best place to position it? Thanks in advance.
Old Jun 7, 2007 | 01:27 PM
Starion's Avatar
I never had any rattling but I did have a leak there when I got my car. I think you just need to get more leverage on it and tighten that **** hard. I slip a piece of pipe onto the end of my ratchet for more leverage.
Old Jun 7, 2007 | 01:49 PM
02pewterZ's Avatar
Do you have the clamp on just the I-pipe, or is it half on the I-pipe and half on the Y-pipe?
Old Jun 7, 2007 | 08:08 PM
Intragration's Avatar
I agree that more torque will probably take care of your problem. Also, depending on how you have the part after the axle hung, it may be pulling the catback apart from the Y. If you can, get it to hang a little further forward, then there will be less of a tendency for the motion and vibration to pull pull the sections apart.
Old Jun 7, 2007 | 08:40 PM
dudeman's Avatar
i had the same problem. i had my buddy weld it up for me though.
Old Jun 8, 2007 | 10:27 AM
02pewterZ's Avatar
Thanks guys.
