ARE valvecovers/ how to do pcv & oil cap?
Old May 5, 2003 | 07:07 PM
highgmc's Avatar
Default ARE valvecovers/ how to do pcv & oil cap?
how is everyone installing the pcv inlet and oil cap in their ARE valvecovers?
Old May 5, 2003 | 07:46 PM
GeorgeC's Avatar
Default Re: ARE valvecovers/ how to do pcv & oil cap?
If you pick up a Jeg's or Summit catalog, you should be able to find a wide variety of oil caps... The ARE valvecovers are simply awesome pieces of work, but they do require some custom fabbing since they are sold with no holes in them whatsoever. That way you can outfit them the way you want them.
I don't have any PCV system per se, but you could easily get some fittings to retain the PCV system. You'd just have to do some looking to find the right size fittings.
Old May 5, 2003 | 08:24 PM
DERTY's Avatar
The Bull
Actually, the easiest and cleanest way is to switch to the LS6 valley cover and run your PCV using that. Then for the oil cap, pull the valve cover off. Clean and nice looking with no excess garbage in the way. The valley cover is only about 50 bucks from SDPC.
