Where to get intake peice from Lid to TB?
Old Jun 17, 2007 | 02:00 PM
SpdFrk1990's Avatar
Default Where to get intake peice from Lid to TB?
I have efilive and did a speed density tune. I want to totally take the maf out but wonder what I should use to run from the TB to the lid. I also want to run a new throttle body or at least get the stock one ported any suggestions?
Old Jun 17, 2007 | 02:09 PM
Tainted's Avatar
ported stock TB. hollow out the MAF, use a saw and dremel and cut out the devider and the other thing
Old Jun 17, 2007 | 02:26 PM
SpdFrk1990's Avatar
I dont want to tear up a perfectly good maf incase I ever want to put it back in. I seen people that had hoses from the tb to the lid but not sure where they got them.
Old Jun 17, 2007 | 02:30 PM
Tainted's Avatar
fernco maybe?
SpdFrk1990's Avatar
Something like this but I have a lid.
Old Jun 17, 2007 | 03:07 PM
Tainted's Avatar
I spy an LS7 in there...
anyhow there was a site I forget the name that sells those hoses in every size under the sun...
Old Jun 17, 2007 | 08:40 PM
02BlackOnBlackSS's Avatar
intakehoses charge air cooler hose
Look it up, they aren't a sponsor.
I believe the 3.5" to 4" works the best, its a little loose on the stock tb, but once you clamp it on it doesn't leak. It fit well on my lid, but if you have a 90mm lid you might want to go with 4" to 4"
Old Jun 17, 2007 | 08:47 PM
SpdFrk1990's Avatar
I have a SLP lid and I might go with a aftermarket TB. What would be a good tb for the factory ls6 intake? Just looked those up they look nice what length would I need?
Old Jun 18, 2007 | 01:42 AM
The hoses are 6" long which works.
Old Jun 18, 2007 | 02:52 PM
SpdFrk1990's Avatar
Do you have any pictures of when you had yours intalled?
