just installed intake. Need help asap
Old Jun 17, 2007 | 09:16 PM
jeff00z28's Avatar
Default just installed intake. Need help asap
When I start the car slowly revs to ~3k. Then it lowers rpms slowly until it gets to 500 and idles rly rough and then starts to die. Any1 have any idea what the problem is? I rly dont think anything got under the intake when I put it in because I checked it a lot but i gues its possible something slipped in at the last minute. I rly have no clue. help appreciated I am hoping ot have it running normal by tomorrow!
Old Jun 17, 2007 | 09:17 PM
jeff00z28's Avatar
i swapped my ls1 out for an ls6. I alread have the egr and air blocked off on the headers.
Old Jun 17, 2007 | 09:33 PM
jeff00z28's Avatar
i also noticed it shows the temperature as 0
Old Jun 17, 2007 | 10:20 PM
jeff00z28's Avatar
any1?
Old Jun 17, 2007 | 10:22 PM
oneBADDz's Avatar
vacuum line?
Old Jun 17, 2007 | 10:27 PM
jeff00z28's Avatar
the little one on the back and the big one are both plugged in. THat one line that goes to the head is kind of creased. would that rly make tha tbig of a difference?
Old Jun 18, 2007 | 09:34 AM
oneBADDz's Avatar
Any vacuum line can make a big difference
Any unmetered air can make a big difference too, like if your tb was leaking around the seal or if you overtighten the intake and crack it
Old Jun 18, 2007 | 11:56 AM
PAGregSS's Avatar
Definitely a vacuum leak. Did you swap over your o-ring gaskets from your other intake or install new ones? Also, did you get the new coolant crossover and plugs?
Temp sensor is located on the front of the driver's side head. Check to see if it's plugged in or broken.
Old Jun 18, 2007 | 12:02 PM
coocooknu's Avatar
I would check your Oil Pressure Sending Unit. It's the thing that is broke most often when doing an intake swap. Double check to make sure it isn't broke, it's all the way in the back behind the intake.
When I broke mine, the car would start, rev way up, and die.
Old Jun 18, 2007 | 01:20 PM
jeff00z28's Avatar
no i didnt swap any gaskets. I did the plugs and pipe. will do
Old Jun 18, 2007 | 01:21 PM
jeff00z28's Avatar
hopefully it isnt but i will check
Old Jun 18, 2007 | 01:25 PM
PAGregSS's Avatar
There's a good chance the intake did not come with the gaskets around each port. That would prevent it from sealing.
Old Jun 18, 2007 | 01:29 PM
SCREAMIN's Avatar
Mine came with the gray gaskets (bought the LS6 intake used) and sealed perfectly. Are you sure the intake is secure and bolted down properly? I know I had to break off a plastic clamp that held some wiring together to get the LS6 to seat correctly. No probs
Old Jun 18, 2007 | 01:57 PM
jeff00z28's Avatar
thx for all of the help i will check all of these things when I get home
Old Jun 18, 2007 | 05:58 PM
jeff00z28's Avatar
there were no gaskets I knew it would be somthing dumb
Old Jun 18, 2007 | 06:39 PM
oneBADDz's Avatar
wows, Good it's something little though.
Old Jun 18, 2007 | 06:54 PM
jeff00z28's Avatar
i broke that oil unit in the back when I pulled it back out Not my day.
Old Jun 18, 2007 | 07:17 PM
oneBADDz's Avatar
I would swear I never let the brake booster hose or anything else touch it when I did mine, but I broke mine too
Old Jun 18, 2007 | 07:49 PM
Zentenk's Avatar
now you have to go look for the socket for the oil pressure sensor, I had to go to 3 different auto parts stores. The stock one seems weaker than the one I bought though. My car did the same exact thing yours did. Tomorrow my car will be put back together to see if I got all the vacuum leaks down. My gaskets were jammed way too far into my intake manifold and didn't look like they were sealing.
Old Jun 19, 2007 | 07:08 AM
PAGregSS's Avatar
You know, the reason I suggested that might be the issue is that I did the exact same thing. I bought my intake used and slapped it on without thinking about it. Boy did the car run rich! Burned the crap out of your eyes because it was dumping so much fuel.
