Alternator Pulley Question
Old Jun 18, 2007 | 09:19 PM
aDaM Ws6's Avatar
Default Alternator Pulley Question
I need help removing the alternator pulley. I have the torx socket that fits inside and I was holdin the outside nut with vice scripts since i have no wrench that is the correct shape for fitting inside the pulley. Anyways I had a friend holding the vice scripts hard and pushing the nut counter clockwise while I was pushing the ratchet with the torx bit in the oppisite direction.
Is this nut by any chance reverse threaded? Or is there something I am doing wrong.
Old Jun 19, 2007 | 08:40 AM
radkon's Avatar
I've never pulled the alternator but I know you need a pulley puller for the power steering pump, maybe you need one for the alternator as well? Check with your local auto parts store, they may have a tool loaner program.
Old Jun 19, 2007 | 09:31 AM
sroach20's Avatar
pull the whole alt off and find someone with an impact. those nuts normally have a lock washer underneath.
