Little wire on the alternator.
Old Jun 26, 2007 | 01:50 PM
Marc '99T/A's Avatar
Question Little wire on the alternator.
What little wire does everyone freak out about that you need to remove when taking the alternator off?
Old Jun 26, 2007 | 01:59 PM
brad8266's Avatar
Its called the exciter wire and the alternator wont charge if its not connected. It is easy to rip the wire from the connector, but if you rip it out you can buy a new connector with the wire from the dealer.
Old Jun 26, 2007 | 03:13 PM
But where on the alternator is it connected?
Old Jun 26, 2007 | 03:26 PM
staringback05's Avatar
the top of the alternator...just follow the wire down past the head
Old Jun 27, 2007 | 04:57 PM
SpdFrk1990's Avatar
I was weirded out about how small the wire was when I removed my alt for the motor mount install.
Old Jun 27, 2007 | 05:02 PM
MeentSS02's Avatar
Kleeborp the Moderator™
You can follow it down from the top of the engine to the top of the alternator...with my AIR system out of the way (and probably even with it in the way), I can disconnect it standing over the driver's side front fender. Very important, VERY small wire.
