FAST intake and 78MM TB for...
Old Jun 26, 2007 | 03:31 PM
V8TJ's Avatar
Default FAST intake and 78MM TB for...
under a grand.
I've posted up a question int he newb tech section and got no responses, so I'll try here.
Im getting a mild cam ( 220/222 I/E, 581 lift, 112Lobe sep.), Lifters, Pro Magnum rockers, pushrods, timing set and springs, milling the stock heads to approx 10.8 or so compression.
I have the opportunity to get a brand new FAST intake and 78MM throttle body for just under a grand. Is it worth it, or should I just go for a LS6 intake...I've found a couple on Ebay for around $500.
Old Jun 26, 2007 | 06:00 PM
Wnts2Go10O's Avatar
getta 90
Old Jun 26, 2007 | 06:10 PM
V8TJ's Avatar
Originally Posted by Wnts2Go10O
getta 90
What will the 90 give me over the 78? Seems I read that until up top the 78 and 90 are pretty much even.
If I could get a 90 for that cost, under a grand. Should I go with that or save the money and get a LS6...?? ARG
Old Jun 27, 2007 | 07:55 PM
V8TJ's Avatar
So anyone else?
Which one, and would sending to to Tony to get it ported be worth it on eiter one, the 78 or the 90?
Old Jun 28, 2007 | 01:46 AM
AaronR's Avatar
At one time a sponsor had both a fast 90 and TB for a little over a "grand".
Old Jun 28, 2007 | 07:01 AM
2000PewterZ28's Avatar
TSP has a Fast 90/ PTM 90 combo for $1050.
