LS6 Intake Install
Old Jun 27, 2007 | 12:15 AM
JGA's Avatar
JGA
Default LS6 Intake Install
Re 98 LS1 A4 - K&N induction and Borla cat back.
If I install an LS6 intake with the stock TB, what are my chances of getting an idle problem after? I do not have tuning capability to adjust the idle at this point.
Old Jun 27, 2007 | 12:18 AM
staringback05's Avatar
no idle problem as long as you re connect all the vaccum hoses back, dont yank the throttle cable and plug everything back up
Old Jun 27, 2007 | 01:02 AM
LS1 ACE's Avatar
^^^ just as the gator fan mentioned. no problem at all. i swapped out my LS1 intake for an LS6 and haven't tuned it yet. no idle problems whatsoever. just take your time and connect everything back correctly. you'll enjoy the nice power gain up top.
Old Jun 27, 2007 | 08:05 PM
V8TJ's Avatar
So it's a straight forward swap? Plug and play basically.
Do you loose anything on the low end, any TQ lose?
Old Jun 27, 2007 | 09:19 PM
JGA's Avatar
JGA
Thanks
Old Jun 28, 2007 | 02:16 AM
you dont lose anything....
Old Jun 28, 2007 | 08:09 PM
Pats Fan's Avatar
I'm about to do this mod. Any tricks/problems to disconnecting the throttle cable? I see it's got a big ole torque spring there...
