O2 Sensor and cat-converter questions
Old Jun 29, 2007 | 02:57 PM
OldeSkool's Avatar
Default O2 Sensor and cat-converter questions
I want to replace all 4 oxygen sensors. Bosch has an "OE style" sensor that is advertised for all 4 locations, is this right? Is $70 a sensor a good deal or no?
While I'm at it, I thought i might check the cats. How do I check and see that they're not clogged or otherwise restricting flow? If they're "BAD", does GM have some kind of warranty on these?
Thanks
Old Jun 29, 2007 | 03:56 PM
staringback05's Avatar
boschs are what most people get, and yes be prepared to shell out some money for them
Old Jun 30, 2007 | 09:33 AM
RevGTO's Avatar
Pontiacerator
GM will replace the cats free if they go bad. When they do, they'll throw a code "catalytic converter low efficiency."
I wouldn't bother spending the money to replace your O2's unless there's an indication something's wrong with them.
Old Jun 30, 2007 | 10:17 AM
slt200mph's Avatar
02 sensors will last a long time..135,000 miles on mine and still going strong .. on the other hand cats are dead weight .. I threw mine away years ago..
Old Jun 30, 2007 | 07:07 PM
OldeSkool's Avatar
Well there appears to be no codes. But my fuel efficiency has dropped 4-5 mpg highway and about 10 mpg city. I haven't changed anything in a long time. Air filter is good. and 2 of the O2's came from a car with headers (doubt that matters) but 2 of them came from someone else's car... if I recall he even told me one was "bad" but since it never showed a code, I didn't think anything of it.
Old Jun 30, 2007 | 07:11 PM
snkeater's Avatar
last time i did my exhaust the guy had a laser temp sensor and he read the temp from the front and the back of the catalic converter on both sides and the temp was different dont exactly know what the temp is suppost to be but hope this helps
