oil pan
Old Jun 30, 2007 | 08:58 AM
xtinctbird's Avatar
Default oil pan
Is it possible to pull the oil pan with the stock kmember in? I'm thinking of unbolting the motor mounts and jacking the motor up, would that give enough clearance to pull the pan or do I need to pull the kmember?
Old Jun 30, 2007 | 11:15 AM
1FSTLS1's Avatar
I would say no. If you are just trying to get to the pickup tube you can drop it an inch or two and get your fingers in there.
Old Jun 30, 2007 | 12:19 PM
xtinctbird's Avatar
I'm replacing the oil pan gasket, I've looked at the situation and I believe I'll be waitning till I have a little more time to do it so I can actually drop the kmember.
