Egr?
Old Jul 5, 2007 | 09:20 AM
chadnol10's Avatar
Default Egr?
maybe i just misunderstood but on installuniversity. They remove the hose from your egr valve to your exhaust manifolds. Is it going to hurt anything if i remove the EGR valve itself or the hose that goes to the intake manifold and plug that also? sorry guys i'm confused as to why you can't remover those 2 pieces i thought you could
Old Jul 5, 2007 | 01:10 PM
HavATampa's Avatar
Sounds like you are mixing up the EGR and AIR removal process. The EGR is only attached to the passenger side exhaust manifold, not both. The AIR system is attached to both manifolds. If you remove either you have to plug the leftover holes. Read the stickies at the top of this forum for how-to's. Here's a few pics from the stickies.
EGR removed:
AIR removed:
Old Jul 5, 2007 | 03:05 PM
chadnol10's Avatar
i would like to remove both i just wasn't sure if you actually remove the egr valve or not.
Old Jul 5, 2007 | 04:32 PM
Dragkid1917's Avatar
either was I, im doin the same thing now. I actually went out and bought that little plug for the manifold too its like 4 bux at ace hardware
Old Jul 5, 2007 | 04:40 PM
staringback05's Avatar
its not going to hurt anything, youll just throw some meaningless codes...just make sure you plug up the holes good, or youll get that ticking
Old Jul 5, 2007 | 05:14 PM
HavATampa's Avatar
Yeah remove the valve. It's not doing any good if it's disconnected. It'll clean up the engine compartment some.
Old Aug 17, 2007 | 08:22 AM
SuperSweet's Avatar
Will just removing the EGR and AIR make the car run differently before getting a tune? I already have the "Service engine light" on from my cats being hollowed out. I plan on getting a tune in about a month. I just wanted to make sure thecar is going to run fine until then.
Also, do I need to order the block-off plates or do you creative guys have an alternative method?
Old Aug 17, 2007 | 08:52 AM
tylerdj's Avatar
Nope, on my first LS1 I removed the egr/air and drove without it tuned for well over a year, and on my current LS1 I've been going with them removed for about 7 or 8 months now and no tune.
 Michael S. Palmer
