Porting MAF, does it run rich or lean?
Jon
but to answer your question, when you port a MAF, since its getting more air, i would think the PCM would compensate by dumping more fuel, making you run rich. but since you can fugg some **** up by porting your MAF who knows what the PCM would do.
If you want to run a bigger MAF or port yours or modify it in any way, that is fine, so long as you get the MAF Table retuned for the changes. Do not just modify it and forget it, do it right and get it retuned.
