O2 sensor Queston
Old Jul 10, 2007 | 07:40 PM
Formula_Power's Avatar
Default O2 sensor Queston
I am looking for new front O2's and i never knew there was a left and right side to them. What is the difference in these and would the car run wrong if they were switched??
Old Jul 11, 2007 | 07:33 PM
anybody?
Old Jul 11, 2007 | 07:50 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I don't think it makes a difference
Old Jul 11, 2007 | 08:19 PM
98C5LS2's Avatar
I just bought new front sensors. They are the same.
Old Jul 11, 2007 | 11:31 PM
ShevrolayZ28's Avatar
Yes, at one point in time the stock ones carried separate part numbers. I don't know what the difference is, maybe it's just wire length. I do know that when you buy aftermarket sensors, they are the same for both sides.
LS1 O2 oxygen sensor (98-02) (AC-Delco #AFS97), both RH = 25312196
LS1 O2 oxygen sensor (98-02) (AC-Delco #AFS98), both LH = 25312197
Old Jul 11, 2007 | 11:36 PM
Quickin's Avatar
The difference IS ONLY wire length. The sensors are identical.
Old Jul 12, 2007 | 12:37 AM
ok thanks guys.
BTW 95CLS2 where did you get your sensors?
I am trying to ind a cheap place to pick them up but I don;t want junk i want either OEM sensors or AC Delco. Also what about Denso? I have heard some good things about them too
