intake manifold?????
Old Jul 12, 2007 | 06:45 PM
RIDINFILTHY's Avatar
Default intake manifold?????
need help !!! i have ls1 stock heads and manifold with 228/230 cam, longtubes,3400 fuddle,3.90 gear,26" et streets. i need to know if i should go with the typhoon 90,fast 90, edelbrock with custom intake elbow to use the tb. i like the edelbrock cause the looks but i really would like to gain some hp. i have 360 rwhp right now and ran 12.40 with street tires and 12.50 with et. streets???? 1.9 60 ft. thanks for the help!!!
Old Jul 12, 2007 | 07:01 PM
kbronSS's Avatar
thyphoon????
if u have the money, i would go FAST 90/90 setup, if not def change it for a ls6. dont know much about the rest.
Old Jul 12, 2007 | 07:07 PM
Wheeler99WS6's Avatar
+1 agreed,...depends on your long term goals. If you plan on installing some ported heads for some serious power then I would go with the Fast 90/90 but if you are just wanting a mean DD then I would just upgrade to a LS6 intake.
Old Jul 12, 2007 | 07:14 PM
kbronSS's Avatar
Typhoon????
Old Jul 12, 2007 | 07:46 PM
typhoon is an aluminum intake by professional products alittle cheaper and i will get heads also
Old Jul 12, 2007 | 11:43 PM
01FormulaTA's Avatar
unless you are gonna get nitrous and need a metal intake get the LS6 or the FAST, IMO I would get an LS6 and use the money you will save to start saving for some heads....
