Please Help!! High idle and I tried everything
Pulled off all the hoses.
One was very very loose and some little sensor looking thing was hanging out.
It connected to the back top of the manifold.
I also cleaned the TB
I will see what she does tommorow.
Thanx guys!!!
And the air cond just came out of every vent, with warm air?
That happened out of no where too. It worked fine a month ago.
Can I re-torque the bolts or do I need to pull and re-gasket it 1st?
I have an 90 Lsx with the direct port.
Hopefully thats a last resort, along with the other broken heads post
Thanx guys!!!
What the hell does that do?
Also, my lsx intake was barely hand tight.
I need to go buy a tq wrench and get that right.
So, as of right now, its still idles high...................
that is definitely my pick for all your woes.
It sounds like ALOT of things were missed when your FAST was installed.
Pinched AC lines, loose runner gaskets, MAP loose, untorqued Manifold bolts, are all potentials.
I'd recheck, if not re-do the whole LSX install, but that's just me.
Why it would just now start freaking out.. I suppose the MAP could have just wobbled out and the AC line wiggled off..
Guys have tried RTV and newer thicker grommets to tighten up the fit.
I wrapped mine in a couple rounds of teflon tape to make it more snug.
I made a small hairline crack on the top front of my intake
Its small enough that some gorilla glue should fix it.
I re-checked all the lines.
I am about done with it.
My hands are tore up.
Cant see or find **** behind this engine
P.S where is the AC line. I am sure of the MAP now, but want to be sure I have found and checked the AC line.
