quick question??
Old Jul 14, 2007 | 08:58 PM
2002RamAir's Avatar
Default quick question??
What size bolts will fit in the empty holes on the end of the heads??
Thanks
Old Jul 15, 2007 | 03:04 AM
staringback05's Avatar
why do you need to put bolts in them?
Old Jul 15, 2007 | 08:39 AM
HavATampa's Avatar
The bolt that holds the EGR valve to the end of the head is M10x1.5x30.
Old Jul 15, 2007 | 08:45 AM
2002RamAir's Avatar
Im making a custom plate to hold my nitrous/fuel noids....
Old Jul 15, 2007 | 08:47 AM
2002RamAir's Avatar
HavATampa.....The valve you are talking about is the one in the back of the driver side head correct?
Old Jul 15, 2007 | 08:54 AM
HavATampa's Avatar
No, it's the EGR valve on the front of the passenger side head. All the bolt holes on the front/back of the heads should be the same size. The AIR valve bracket on back of the drivers side head is held on with a M10x1.5x20, same as the EGR bolt, just a little shorter.
