No PS, No AC belt setup?
Old Jul 15, 2007 | 08:56 PM
LS1HeavyChevy's Avatar
Default No PS, No AC belt setup?
Hello, I'm about ready to start up my motor but haven't found any good info on how to arrange the drive belt with no accessories. I'm just running the Corvette alternator, water pump and balancer. I have one idler pulley now, but don't know where to put it or if I need more. Any help (or a drawing) would be really kick-***. Thanks for your time.
Old Jul 16, 2007 | 04:29 PM
Formula_Power's Avatar
well i'm not sure about your application. but if you delete the AC and the PS and then use a electric water pump there are companies that make a belt tensioner so you can run the Alt. and crank pulley only...but if you are still planning to use the stock water pump i'm not sure what to do
