A/C question
Old Jul 17, 2007 | 04:53 PM
MUSTANGBRKR02's Avatar
Default A/C question
I just fixed my A/C and it now works but is not as cold as it was. I filled it with cheap advance auto r134a in a can till i make sure of no leaks. will getting it serviced at a shop make a difference or is it a waste of money??
Thanks
Old Jul 17, 2007 | 05:04 PM
2001NBMZ28's Avatar
Is it charged to the correct pressure for temp/humidity? Don't think the brand of R134a would make a difference.
Old Jul 18, 2007 | 09:36 AM
it is charged correctly. I am just not as happy with the temp. of it.
Old Jul 18, 2007 | 10:03 AM
89Formulaws6's Avatar
get a actual vent temp reading
what was wrong with the a/c system in the first place?
Old Jul 18, 2007 | 01:07 PM
a wire on the connector was rubbed thru and i removed the lines to more easily change spark plugs up top.
I will get a reading today.
Old Jul 18, 2007 | 11:14 PM
did you evacuate (put the system in a vaccum) the system after opeining the lines?
