probably a stupid question
Old Jul 24, 2007 | 11:21 AM
junkz28's Avatar
Default probably a stupid question
anyhow, with hptuners hooked up, it's telling me that my right bank o2 sensor is dumping 90% fuel at idle while the left is at 10%. Apparently, this all happened after my header install. First, what would cause this? Also, what should i be checking?
Old Jul 24, 2007 | 01:22 PM
staringback05's Avatar
hmm those are weird numbers, but i guess im more familiar with efi live then hp tuners....
after your header install it looks like either you have a leak near the sensors or a bad sensor themselves...this will cause the trims to be off
Old Jul 24, 2007 | 01:24 PM
brad8266's Avatar
Check for exhaust leak on the header and if there are none then replace the O2 sensors.
Old Jul 24, 2007 | 04:11 PM
junkz28's Avatar
i had the car scanned today.
the codes are P0133B Heated Oxygen Sensor Slow Response (Bank1)(Sensor1)
and P1133B Heated Oxygen Sensor Insufficient Switching (Bank1)(Sensor1)
Any help with this? I tried searching and just found that people were having trouble with the sensors not getting hot enough, but if that was my case i'd have a problem with both sensors instead of 1.
Old Jul 25, 2007 | 11:19 PM
junkz28's Avatar
anyone?
Old Jul 26, 2007 | 12:18 AM
SStealth00's Avatar
replace your 02's
Old Jul 26, 2007 | 06:18 AM
brad8266's Avatar
Replace both O2 sensors with a set of Bosch 13111. They have the longer wires so there is no need for extensions or splicing.
