What are the best cats?
http://www.eadperformance.com/catalo...3efdab3cc0e599
i ordered mine from them and they came in pretty quick. I did have to call and order though because their shopping cart wasn't working then. It may work fine now though. Also, my car is loud as hell even with them on!
http://cgi.ebay.com/ebaymotors/3-Met...QQcmdZViewItem
I am doing it b/c my car with the tail pipes ran out the back and the cam when coming to a stop it smells soooooooo bad.. right now it is dumped and ther is no smell. but man is it loud as hell in the car.. if you go to the multimedia section i posted sound clips of my car dumped and vid onsode the car
EDIT: what is soo good about those cats vs others. Those cats you posted have the screen in the inside and what not right? I want to get rid of some of the smell
Carsound = Magnaflow.. Carsound is made by magnaflow..
where can i get magnaflow/carsound, random tech and others?
actually, they did!
Metal core cats weren't out when they did the test. Metal core flow better and don't muffle as much Last edited by jimmypop13; Jul 24, 2007 at 06:16 PM.
MAGNAFLOW PERFORMANCE EXHAUST METALLIC-CAT
59950 Series – Compact High-Flow Performance Catalyst (Center / Center)
High flowing compact packaging catalyst. 59959 was tested (1000 cfm range @ 28" of H2O) to flow ~570 CFM. The one piece spun body short neck design and 400 cell density metal composite core make for excellet flow and extreme durability. The compact series uses all the same features as the ultra high-flow but provides for SMALLEST packaging avialable in high performance cats.
here is a link to some advantages to metal core over ceramic:
http://www.warpspeedperformance.com/metalsubstrate.htm
Or can i get cats, weld them in and be done. man it has been a long time since i ran a car with cats lol
here's mine:
here's mine:
sweet. so you really recommend the ones that you posted the link about? and i found the specs on them too. So that was good
but this is what i had in mind
that is awesome. Did you have a chance to listen to my sound clips? Ohh and will these cats cut back on the raw fuel smell???
Here is a clip of mine. You have to turn up the volume bc my camera sucks like that. The car is actually extremely loud at idle. Much much much louder than my cammed LT/ORY/GMMG trans am that I used to own.
yup that sounds sweet. Here are the vids that i am talking about that i do not think that you heard. And yea the WOT one sounds
DUMPED
