Problem codes
Old Jul 24, 2007 | 04:34 PM
bigdaddy1010's Avatar
Default Problem codes
My car has an slp maf sensor and recently it starting throwing a mass air flow low input code and it seems to be making my car cut out at constant speeds. One of the o2's went bad so i put one in and it fixed the o2 code. Then a week or so later the other o2 went out and i put one in that side and fixed it. About a day later, now both o2's are throwing a heater circuit code.
Old Jul 24, 2007 | 05:11 PM
2001NBMZ28's Avatar
Hmmm....have you looked at your ENG SEN fuse? Something easy to check, MAF and 02's are both on the same circuit.
