Squeaks
Old Jul 27, 2007 | 02:43 PM
pinesol_hater's Avatar
Default Squeaks
So my car has decided to squeak quite loudly now after it rains, and since it is nearly time to buy an ark here in Texas I'm thinking I need to remedy it. I think the noise is coming from a pulley but I'm not sure which one. Do they make aftermarket pulleys to replace each of the stock ones? If so, do you recommend changing them all? Any advice in this area would be helpful and much appreciated. Thanks in advance!!
Old Jul 29, 2007 | 01:27 AM
iamnitrox's Avatar
Maybe its just a belt. Trying replacing a 30$ belt before you replace 100$ worth of pulleys
Old Jul 29, 2007 | 06:26 PM
rayray979's Avatar
I have the same problem it sounds like its coming from the pully next to my ac...
its a new belt only has a few hundred miles on it
Old Jul 29, 2007 | 08:33 PM
FireSilverLullaby's Avatar
They make some stuff in a can called belt dressing i think thats supposed to stop squeaks. you could try some of that
Old Jul 29, 2007 | 09:32 PM
TA adam's Avatar
im having the same problem i hate it i know its not the belt but it is one of the pulleys but when im acelerating ti dosnt sqeak and the one time i went to a shop to get it checked out it didnt want to squeak
Old Jul 29, 2007 | 10:25 PM
99PewterT/A's Avatar
Same problem here, check your idler pulley. Also does it when the engine is cold.
