Volant Cold Air Intake
I have a lid which faces down and my FTRA pulls air from the outside and under the car which is as cool as its going to get. The air goes up into the air box and cools the intake temperature by atleast 10degrees over the stock setup. It is also more of a frictionless path of air compared to the volant. FTRA has a bigger opening and makes less turns.
I did my research because I was going to get volant too but changed my mind. Research has actually been done on FTRA so check it out.
I have a WS6 with a Volant and love it. To get it to seal, you have to get a length of copper pipe insulation (foam tube) from the hardware store. It comes split down the middle and will fit over the stock rubber seal on the box perfectly. The good thing is it's cheap and will seal the WS6 hood well.
I don't have any experience with Camaro or SS hoods, so I can comment on them.
Marc
