Ls6 PCV
Old Jul 31, 2007 | 01:38 AM
phoenix1987's Avatar
Default Ls6 PCV
I am about to install a LS6 valley cover and do the Ls6 PCV mod. I have 98 valve covers and have no idea how to route this new PCV system, as I do not have one now.. I do have a metco breather, mounteed on the drivers side. A friend told me to run a hose from the ls6 valley cover to the intake. If I do this this, do I need to install a PCV valve between the valley output and the intake? Should I connect the valley cover outlet to the intake or throttle?
Sorry for all of the questions, just a little confused.
I will not be running a catch can either. Not until winter mods come into play anyway,
Old Jul 31, 2007 | 09:01 AM
warp10's Avatar
You can block both sides of the valve covers. You will now get the PCV pressure from the valley instead of the valve cover area.
Old Jul 31, 2007 | 09:11 AM
mzoomora's Avatar
14 Second Truck Club
Check LS1howto.com, they explain the whole thing and have pictures.
Old Jul 31, 2007 | 09:23 AM
sroach20's Avatar
you need to run a pcv in between. the hose goes into the intake. the throttle body is what goes to the tube on the front of the passenger side valve cover.
