question about EGR, AIR, and TB bypass
Old Jul 31, 2007 | 04:29 PM
UnZFeat'd's Avatar
Default question about EGR, AIR, and TB bypass
i was wondering if it is at all possible to do the AIR and EGR deletes, as well as the TB bypass, without having auto tap. the only thing i have is a GM code deleter. is it possible to do with only tools and nothing electronic but that? This is on a 99 SS. Thanks
Old Jul 31, 2007 | 04:35 PM
tylerdj's Avatar
I removed mine a several months ago without having the codes deleted. I'm pretty used to seeing an SES light now
Old Jul 31, 2007 | 04:52 PM
UnZFeat'd's Avatar
does it still help if you just remove them? is there a link to removing the AIR? i saw the link for EGR on installuniversity, and how can i tell at what percentage the blade is open?
Old Jul 31, 2007 | 04:57 PM
tylerdj's Avatar
The first page on this link has some good info for removing egr/air as well as some links to write-ups on how to remove them. Towards the bottom somewhere it shows you what to grind off to make the TB open 90 degrees also. It doesn't really make a difference whether you remove the codes or not...all it is going to do is not set off the SES light.
LINK
Old Jul 31, 2007 | 04:58 PM
Magnet's Avatar
^^^ he beat me to it lol
Old Jul 31, 2007 | 05:28 PM
UnZFeat'd's Avatar
it didnt say anything about where to grind the bump down at. is there anything else that shows where to grind it down to before i throw a code for it being over 90 degrees?
Old Aug 1, 2007 | 08:29 AM
tylerdj's Avatar
Sorry about that, it was on a different sticky. Here's a link to it...it mainly talks about porting/polishing but towards the bottom it tells how to do the bump stop mod.
LINK
