Simple Ls1 mods
Old Aug 3, 2007 | 03:08 PM
TA1364's Avatar
Default Simple Ls1 mods
Just got a 98 trans am, whats some simple not to costly ways to get more out of it?
Old Aug 3, 2007 | 03:11 PM
LTLRDSS's Avatar
lid, cat back, ls6 intake..........................................
Old Aug 3, 2007 | 03:26 PM
3rdgentug's Avatar
lid, filter, free ram air mod, work great and can get all pretty cheap and w/ out much time involved
Old Aug 3, 2007 | 03:39 PM
DANOZ28's Avatar
lid $100, catback $300- $1000,they just sound diff, next free ram air or i purchased SLP cold air $125. this involves cutting the plastic base under air lid and filter, back close to radiator. on my 99 egr sticks /hangs down. can be trimmed for better air flow near throttle body on intake. install university website shows how. after these my opinion is sub frame connectors, lca's lower control arms, panhard bar these suspention mods will give you better traction because no wheel hop. just my 2 cents super chevy mag may 2004 had an article ls1 do's and donts. check that out.
Old Aug 3, 2007 | 06:49 PM
Viper's Avatar
http://www.ls1howto.com/
http://www.installuniversity.com/
Good start there
As mentioned, lid, porting your throttle body, catback exhaust, lca's for handling ($200), cutting up the EGR, shift skip, if it's a 6 speed you can do the drill mod for consistent shifting, find a friend with HPTuners (with a 98 license) and do some quick hits to maximize tuning (helps even when stock).
Old Aug 3, 2007 | 08:18 PM
0utLawZ28's Avatar
there are tons of free mods you can do get p/p tb there good way to get cheap power i just got p/p form devine performance it looks good well install this week end
Old Aug 4, 2007 | 03:05 PM
SSinNC's Avatar
instead of a catback, just throw a cutout on there.
Old Aug 4, 2007 | 07:13 PM
TA1364's Avatar
How do you shorten up the EGR ive never messed with this stuff before
 Michael S. Palmer
Old Aug 7, 2007 | 02:21 PM
DANOZ28's Avatar
install univ has step by step picture instructions i used myself. that said loosen the 2 bolts on intake manifold where tube attaches near throttle body. then (put down towel ) and cut the thin metal 1.5 inch round EGR with dremmel or hack saw. then i used a file to smooth ruff edges. put back in place and 2 bolts. wa la!
Old Aug 7, 2007 | 02:53 PM
01CamaroZ28's Avatar
i 2nd the cutout. If my car didnt have a borla on it already i wouldve skipped the catback and went with some cutouts or true duals.
