5.3L heads
Sorry, couldn't resist...
Since the Vindicator and other similar cams are usually made to clear with stock heads and gaskets, it will depend on the valve drop difference between the 5.3 heads and 853/241 castings. It will probably require at least some clearancing to work, depending on LSA and ICL.
That cam should work best with a .040 gasket and a 59 or 60 cc chamber, depending on fuel octane and the size of valve pockets required to clear.
