oxygen sensors
Old May 21, 2003 | 07:50 PM
chevy1322's Avatar
Default oxygen sensors
i have a 1998 camaro z28 and i just had my car put on a computer cause it was running to rich it says my two front oxgen sensors are bad are they hard to change?do i have to reprogram my computer? if so how? thanks
Old May 21, 2003 | 08:15 PM
wrencher's Avatar
wrencher
Default Re: oxygen sensors
Not hard to change, 7/8 wrench to remove them < then you'll need to clear the code (s).
Old May 21, 2003 | 08:36 PM
chevy1322's Avatar
how do you clear the codes? thank you for the info
Old May 22, 2003 | 12:17 AM
Krazy98Z28's Avatar
you can have autozone clear the codes for you
Old May 22, 2003 | 09:04 AM
chevy1322's Avatar
theres no way i can clear the codes myself?thanks
Old May 22, 2003 | 09:51 AM
Viper's Avatar
Unless you own atap, no.
Old May 22, 2003 | 01:10 PM
TaTommyWS6's Avatar
You don't need Atap, just reset your PCM. Either pull the correct fuses, or just disconnect the battery for a few minutes...
Tommy
Old May 22, 2003 | 09:08 PM
Bradygoodz's Avatar
to reset your pcm turn your key to ignition but dont start it pull your pcm batt and pcm ignition then turn your key to the off position wait a few minutes then put the fuses back in place and start your car, Im pretty sure thats how to do it its been a while since i've done it tho
 Michael S. Palmer
