The strenght of JB weld?
Old Aug 13, 2007 | 08:36 PM
1987firechicken's Avatar
Default The strenght of JB weld?
My QTP headers have an issue with the HVMC the primaries are not sealed by the welds looks like it never bonded Can I put some jb weld and seal them the rest of the way up? Or will it just bake and blow out. Seems like I have alot of questions after this install.
Old Aug 13, 2007 | 08:48 PM
Grifter's Avatar
I have always had good luck with JB Weld but I've never used it for exhaust. Check to see if there is a temperture rating.
Old Aug 13, 2007 | 08:57 PM
Sideways240sx's Avatar
From my experiance with it, it may hold for a week or so, but with the drastic change, from very hot, to cold it will crack. Especially with the vibration. I have used the stuff a little bit, but never had any luck with it on anything as hot as header/exhuast. Id see if an exhuast shop could maybe weld it up while they are on the car.
Good luck.
Chris
Old Aug 13, 2007 | 09:03 PM
FireSilverLullaby's Avatar
You might want to try some stuff called quick steel. it comes in a tube and you can buy it at autozone right next to the jbweld. Ive had better luck with that stuf and its alot easier to use.
Old Aug 13, 2007 | 09:13 PM
sroach20's Avatar
most auto parts stores have some jb weld type stuff that will handle 1200 to 1500 degrees.
Old Aug 13, 2007 | 09:19 PM
Sorry for the newb question but can they get a weld in there with it all together? It looks like some shitty work by the crew at QTP the welds are sitting about 2-3 MM off the primary. I would like just to put some compound like JB weld and put it in a turkey injector and just layer it up untill it seals.
