part # for front 02 sensor?
Old Aug 17, 2007 | 03:09 PM
Nimitz87's Avatar
Default part # for front 02 sensor?
bosch 13111 is that what im looking for?
im tripping a P0135 code which is
02 sensor heater circuit malfunction bank 1 sensor 1.
what side is this?
Chad
Old Aug 17, 2007 | 03:10 PM
tylerdj's Avatar
Do you have long tube headers?
Old Aug 17, 2007 | 03:14 PM
Nimitz87's Avatar
yes Pacesetter LT's
Chad
Old Aug 17, 2007 | 03:17 PM
tylerdj's Avatar
Bank 1 is drivers side, Bank 2 is passenger side. Sensor 1 is precat sensor, Sensor 2 is postcat sensor.
It's your driver's side O2. 13111 is the part# for the rear vette O2's that people usually replace their front O2's with whenever they install headers.
Old Aug 17, 2007 | 03:19 PM
Nimitz87's Avatar
thanks, so i should go with the vette rear 02 sensor? or some other sensor?
Chad
Old Aug 17, 2007 | 03:21 PM
tylerdj's Avatar
I would...thats what I've ran on both of my ls1's when I installed headers.
Old Aug 17, 2007 | 03:23 PM
tylerdj's Avatar
This is from the sticky at the top of this section:
(bosch 13111vette rear o2s) These have a stronger heating element, and a longer wire harness, they can often solve front o2 insufficient switching errors, due to the higher wattage heater, also they eliminate the need for extensions, as the harness is long enough to reach the stock f body o2 connector
Old Aug 17, 2007 | 03:32 PM
Nimitz87's Avatar
yeah i read the sticky but there were so many different types of 02 sensors...wasn't quite sure.
thanks i'll pick one up after i sea foam.
what does the bad front 02 sensor do as far as driving/performance?
is it bad to drive it?
Chad
 Michael S. Palmer
Old Aug 17, 2007 | 03:34 PM
tylerdj's Avatar
Your A/F will be off. I (believe) it will make you run rich.
Old Aug 17, 2007 | 03:44 PM
Nimitz87's Avatar
yeah im smelling alot more gas and popping
thanks for the quick replies tylerdj one more quick question the car was recently dyno tuned and never threw the code on the way home it did however...could my 02 sensor "going" bad have caused lower numbers on the dyno?
Chad
Old Aug 17, 2007 | 03:55 PM
tylerdj's Avatar
It shouldn't have affected your tune at all since the light wasn't on, so the sensor should have been good. The stock o2's being further away from the headers just causes them to go bad pretty often.
Tyler
