help in removing the a/c crap
Old Aug 17, 2007 | 04:31 PM
heavy6.0's Avatar
Default help in removing the a/c crap
So how do you get the rest of the A/C unit out from behind fender well or do you go under the dash?
Old Aug 17, 2007 | 06:37 PM
chuckyt1's Avatar
Under the dash for most of it. There are a couple of bolts that you need to get from the engine compartment. They can be a pita. Use a very long extension and a swivel, slide it in under the headers. There's also one, (I think), under the PCM.
It's worth it...
Old Aug 18, 2007 | 10:16 PM
theblur98ss's Avatar
Yup gotta pull the dash to get the rest of it. If you want to keep your heat I'd just leave the evaporator in there.
Old Aug 19, 2007 | 02:34 PM
billybadd's Avatar
Pull the dash and yank all that ****. Unless your up north, you dont need heat.
