Oil Pressure too High?
I run 6 quarts of mobil 1 synthetic with a k&n filter. Is it a problem for my pressure to get up this high?
My stock LS1 with a stock LS6 pump does around 80psi on cold start up and on WOT. What weight are you using ?
I use 10w-30 or 10w-40 depending on what wal-mart has on the shelf in those 5 quart jugs.
Today while cruising down the interstate at ~80 it was a little above 40 psi. At 80 I am around 2200 rpms.
Your fine as far as the oil pressure goes. I have and LS6 Ported and shimmed oil pump. My pressure is pretty good.
oncold start up it is at 70 PSI, WOT about 75 PSI crusing like at 55 PSI
I too run M1 5W30 Fully Synthetic.
