Pulley install instructions?
Old Aug 22, 2007 | 01:01 PM
chadnol10's Avatar
Default Pulley install instructions?
I have found directions on here for all the work i've done to my car. However i can't find directions for the underdrive pulley. I haev an ASP pulley and i woudl like to put it on tonight. Is there a thread anywhere? I did try the search.
Old Aug 22, 2007 | 04:30 PM
MeentSS02's Avatar
Kleeborp the Moderator™
www.ls1howto.com
Just look under anything that has to do with a cam swap since the pulley has to come off for those. It'll tell you how they removed theirs and how they reinstalled it.
Whatever you do, do NOT draw the pulley on with the stock length bolt or by hammering it on. The stock length bolt will most likely strip the first couple of crank threads, and hammering it on is just a bad idea. I bought a tool from a guy on here to install my pulleys that is a big threaded rod with a thrust washer on it. But if you are installing it tonight, chances are you don't want to wait to make sure you have the right tools...just be careful.
