Am I missing anything?
Old Aug 22, 2007 | 08:39 PM
striker754's Avatar
Default Am I missing anything?
I am assembling an ls1 from the bare block. Am I missing anything here?
cam sensor
crank sensor
oil pan and tray in the pan
oil pan gasket
pickup tube
front and rear covers with bolts and gaskets
crank pulley
oil pump bolts
valley pan with bolts and gasket
knock sensors
water pump with bolts
cam retainer plate with bolts
cam gear with bolts and chain
valve covers with gaskets and bolts
rocker arms with bolts
lifter trays
tensioner assembly
idler assembly
coilpacks
alternator
starter
belt
Anything else Im missing?
Old Aug 22, 2007 | 10:35 PM
Tainted's Avatar
i think you got it all other than a new crank pulley bolt
Old Aug 22, 2007 | 10:38 PM
striker754's Avatar
yep i have one of those. also have the thing that bolts to the block above the oil filter
Tainted's Avatar
i think thats all of it then
