Exaust Question?
Old Aug 24, 2007 | 08:45 PM
NC98Z's Avatar
Default Exaust Question?
I've got a Dynatech Supermax exaust system. It has a Y-pipe that changes 2-2 1/2 pipes into a 3 inch single. If I bought another Y section and expanded it enough to slip on my Y would it have the same effect as a XPipe? I could run my duels from there on back. Weird Idea? Good Idea? Somebody gotta tried this by now.
Old Aug 24, 2007 | 08:56 PM
bsf's Avatar
bsf
I do not like that idea, though it may be cheaper than the alternative. If you want to run duals, I would suggest cutting the merge out and installing a proper crossover. I think you would be largely negating the benefits of a dual system with that constriction at the merge. The cross-sectional area in the middle of my dual system crossover is probably equivalent to the sum of the cross-sectional area of both inlets, if not more. I am not real comfortable with flow dynamics, but this seems intuitive.
Old Aug 24, 2007 | 10:36 PM
sixvi6-camaro's Avatar
It won't be like an X pipe because an X pipe is 2 pipes that share a common hole in between them but they don't actually merge into a single pipe. your idea would actually be combining them completely into one pipe.. then splitting them back out to 2.
