LT1 vs LS1 radiator pics
the plastic on mine cracked which was the whole reason I upgraded... if i saw a radiator with plastic on it while i was shopping for one that was a definate "NO" in my book... I thought that the plastic end caps were there for some vibration absorbtion, as well as being super cheap compared to all aluminum...
Does the BeCool have sturdy mounting tabs in stock location?
By the way: over here it's almost impossible to find a used cooler and in the US they go for $50 - $100. Who would be so kind and help me to find one + shipping?
What other mods? Mine is a 1998 M6.
Is that an option to leave it alone and add an oil cooler?
Same result?
Same result?
What are you trying to achieve? Cooler oil temps?
Right now I need 200-210F at WOT, this means that while cruising the ECT should be 190-195F. In summer the car speed (highway) is not enough to reach this temperature and the low speed fans are always on.
I honestly don't know if this is good for the fans motors. Maybe it's not an issue, maybe it shortens their life...
That will tell you just about all you need to know about the SLP and LT1 radiator. It is a good source of info.
What year is your car? Is there something you had to modify? Or is it just a drop in?
Mine is a 98, can I pick up no matter radiator from a 93-06 F-Body?
Stefano
